Cannot read text with OCR - surface automation
23-01-19 04:56 PM
I'm currently trying to read a PDF with surface automation. I've spyed the document window, defined the region where the text will and assigned a font for the text.
When I use the "Read text with OCR" on the read stage, I get the following error :
Internal : Failed to perform step 1 in Read Stage 'Reader1' on page 'Read PDF Content' - The system cannot find the file specified.
The version used is BP 5. Has anyone encoutered this issue before?
Betty
24-01-19 01:56 AM
My first thought is that there is a typo in the path variable.
I have found the built-in OCR to be not that consistent yet. I am using Nuance PDF to read my PDFs and it is doing a much better job. If you have access to Nuance, you might want to try that. You can open the PDF and write straight to a Word or Excel document. From there, your job is easier.
Hope that helps.
