28-06-24 04:33 PM
I am intermittently experiencing inconsistency in PDD generated from capture.
Suppose while recording - there are multiple option visible vertically and in the PDD generated - Capture end up showing the wrong option selected.
is this due to how fast options are clicked? if yes, Any recommendation on how slow recording need to be performed
09-07-24 09:39 AM
Hi @Neel1, hope you are well.
If you see this inconsistency in the Capture canvas as well after recording your process, it is likely to be a memory issue that is preventing Capture from catching up with all the actions you are performing during the recording.
In that case, I suggest closing down all applications that are not required for your recording and perform your actions slower to see if that makes a difference.
Thank you for your post.
09-07-24 09:39 AM
09-07-24 10:12 AM
Thanks @omidhosseinitabar for feedback. Will try to implement your suggestion.
