Checking Blue Prism Extension Status on Edge without launching
Eng_JuanChew
I am trying to check the BP extension status on Edge and make sure it is enabled. However, if it is not enabled at the start of the process, BP will not even be able to connect to the Edge instance. Therefore, I would like to check if there is a way to check the status of the BP extension without launching Edge.
Thank You.
Off the top of my head: Have you tried checking the extension folder exists in it's installation location?  A quick google search will tell you where those locations may be.
