01-02-23 10:25 AM
As I could see the 'Blue Prism 7.0 Citrix integration' document where it has mentioned that Blue Prism should be installed in the VDE that we are automating. Is that Blue Prism application need to install?
Also, it has mentioned that "Blue Prism communicates with the Citrix VDE using the virtual channel driver which forwards the data over an ICA channel. The data is received by the Blue Prism AppMan.Service.exe and is forwarded to the Blue Prism Application Manager via internal communication." what is ICA channel, Blue Prism Application Manager here ?
Is there any alternative way to do connect to any VDE or RDP without Blue Prism installation?
02-02-23 10:37 AM
