Code Stage Output Parameter not working
MohiniShelke
Hello All,
I am using code stage using and  I have written some code for filter.
This will return data into DataTable variable.
But when I am defining it in Output parameter it throwing some error.
Below is the part of code :
string strSummaryFileName = "C:\\BankOfSingapore\\HongKong\\Input\\Headcount Summary\\v2 Headcount Summary (LnD)_with Staff Movement.XLSX";
strSummaryFileName = "C:\\BankOfSingapore\\HongKong\\Input\\Headcount Summary\\v2 Headcount Summary (LnD)_with Staff Movement.XLSX";/
string strFunctionalTitleFileNm = "C:\\BankOfSingapore\\HongKong\\Input\\Functional title\\Functional Title.xlsx";
string strTitleSheetName = "M2 Only";
string strFileExtension = ".xlsx";
DataTable dtHeadCountSummary = ReadHeadCountSheet(strSummaryFileName, strFileExtension);
DataTable dtFormatedSummary = ChangeTheHeaderNm(dtHeadCountSummary);
DataTable dtFunctionalTitle = ReadFunctionalTitle(strFunctionalTitleFileNm, strTitleSheetName, strFileExtension);
DataTable dtReportData = FilterHeadCountSheet(dtFormatedSummary, dtFunctionalTitle); }
dtReportData -->This is the DataTable that i want as collection out from Code stage into BluePrism.
This is the is Output Varaiable:
This is the ereor message:
Description:
1.Compiler error at line 8: A local variable named 'dtReportData' cannot be declared in this scope because it would give a different meaning to 'dtReportData', which is already used in a 'parent or current' scope to denote something else
2.Description: Compiler warning at line 35: The variable 'ex' is declared but never used
Repairable: No
Can anyone knows what is the issue here?
Thanks in advance
Mohini Shelke
vElement It
PSSupport
You can probably omit the leading "DataTable" from this line, as dtReportData is already defined for you by virtue of adding it as an Output parameter.
James Man, Professional Services APAC
