I am trying to reference an external DLL in BluePrism Object. It shows no error while compiling but while executing the stage, it throws an error, "The reference dll could not be found." Any help would be appreciated.
Hi Vijay,
you need to referance the external dll which you are using in the Blue Prism Object. Go to the insitalise tab on that object and go to the code option from property. Add the referance of the dll to the external refarance section.
Ayan
