Collection field values are not visible unless clicked
I came across something weird today and am unsure what is happening. I'm using 6.10.5.
I have a paragraph of text that I'm extracting from a webpage. I'm using Split Text (Utility-Strings latest version) action using a keyword to split all sentences in a collection.
Now in my result collection, all sentences are rightly split but not able to see all rows unless clicked on a specific row.
In fact, it has data in all rows but BP only shows when clicked. Also there are no leading spaces in the values.
This is my original block of para.
Also, when I use this collection and use a decision stage to check that the statement starts with "Today" keyword that is also not working as usual.
Not sure what is happening, anyone noticed this before or if something that I'm doing wrong.
Thanks & Regards,
Tejaskumar Darji
Sr. Consultant-Technical Lead
ewilson
Hi @Tejaskumar_Darji,
Any chance you have some white space (specifically a CRLF) at the beginning of each entry?
Hi Eric,
No I don't see any space or char before the first letter in each row. I suspected it to be whitespace but nope nothing is there.
Thanks & Regards,
Tejaskumar Darji
@Tejaskumar_Darji,
Very strange. I've checked our ticket system, but I don't see anything similar to this. I'd suggest restarting your Blue Prism instance and see if the behavior persists. If it does, I'd open a ticket with support.
Thanks, much @ewilson ​
Thanks & Regards,
Tejaskumar Darji
