Comparison of two images by using bP
19-04-18 03:49 PM
i need to compare two images by using BP. if two images are identical we should return the result as yes else no. But i am not able to achieve it through BP. pls provide your thoughts and suggestions on this.
Kirankumar Mahanthi.
19-04-18 10:51 PM
Have you tried and expression such as [Image Data Item1]=[Image Data Item2]
25-04-18 08:57 PM
Try using BO - Utility - Image Search, Action Find Image, it is a BP supplied object that can compare 2 images and has a flag output
12-12-22 01:16 PM
I think you can still use wait stage with "Matches image" condition.
store the image1 and 2 in a folder try to match if image1= image2 in the above condition.
Gayathri S
Application Engineer
DXC Technology
Gayathri S
DXC Technology
