I have added the external references and namespaces in Code Options tab as below:
External References:
System.Data.dll/System.Xml.dll/System.Drawing.dll/System.dll
Namespace Imports:
System/System.Drawing/System.Diagnostics
There is an error message when I click the ""check code"" button even if the global code tab is empty in Business Object information stage ,the original message is like this
Page Stage Name Type Action Description Repairable
Initialise Stage1 Error Validate Compiler error at top section line 25: 应输入类型、命名空间定义或文件尾 No
It may demand to input the type,namespace definition or EOF(end of file).
Do you have any idea?
BTW,I have found the space length of Code Stage is too short in Foundation Tranining and one sample wrote with VB.net, Is there any supplementary learning documents about code stage in Blue Prism Support or somewhere?
