Connection between Bluesprism and Database not sql server
08-02-18 09:02 PM
we are currently trying to create a connection between a Blue Prism process and a mySQL or HFSQL data base.
Do you know a VBO object that could allow us to do that? So far we've been using the SQL server VBO, to no avail.
Any help will be appreciated.
Thank you in advance!
09-02-18 01:03 PM
The SQL Server VBO won't work but the OLEDB VBO might. You'll need to research the necessary inputs for a MySQL connection - connectionstrings.com is usually good.
06-03-18 11:16 AM
Please use the VBO - Data - SQL Server => Action - set connection => Action Execute => Query on the specified database.
