Covert Json Response to Required Data Formats
vinodchinthakin
Level 9
Hi All,
I would like to convert Json response to required data formats.
1. I am using an API, which compresses image and output response will be in Json(Text) format. How can I convert Response content into Image(Binary) data type?
2. I am using an API which converts HTML to PDF and output response will be in Json(Text) format. How can I convert response content into PDF(Binary) data type?
Note: we have utility JSON which helps in converting Json to Collection. But we need to convert Json to other formats, do we have any Assets or Codes for that?
Any suggestions!
Thanks in advance.
VINOD
vinod chinthakindi
15 REPLIES 15
Hi Vinod,
If you can share examples for both then it will be helpful to look into possible solutions.
For 1 - Does the JSON has a base64 encoded text?
For 2 - Does the JSON has any server path to the PDF file?
Shashank Kumar
Singapore
+6581326707
Thanks for quick reply shashank.
Pls find below screenshots.
2.  there is no any server path to the PDF file
Query: If the output of the API response is Image/PDF, how can we download/store in local system from API?
vinod chinthakindi
Hi Vinod,
1 - This seems to be in binary format. What does the API documentation say? Utility - HTTP has an action called HTTP Request File which you can use for this.
2 - What does the API documentation say about the response body and response content? If it's binary already(which seems likely to me) then you can use the same action HTTP Request File
Shashank Kumar
Singapore
+6581326707
Hi shashank,
API documentation doesn't says anything on API response.
I don't see any HTTP Request File in HTTP Request VBO.
Can you name the action and inputs params to be provided?
vinod chinthakindi
Hi Vinod,
You can download the latest version of HTTP Utility from DX https://digitalexchange.blueprism.com/dx/entry/3439/solution/utility---http
Shashank Kumar
Singapore
+6581326707
Hi Shashank,
I tried with HTTP Request file by passing URL and method, but getting an error "empty path is not legal"
vinod chinthakindi
Hi Vinod,
Did you pass the FilePath in the input parameter?
Shashank Kumar
Singapore
+6581326707
Yes I included Url of File within API for testing
http://api.pdflayer.com/api/convert?access_key=access_key&document_url=https://pdflayer.com/downloads/invoice.html&secret_key=secret_key
vinod chinthakindi
Hi Vinod,
FilePath is another parameter in the action. This is the pdf file path where the binary data response from the API will be written into. For example - C:\myfile.pdf
Shashank Kumar
Singapore
+6581326707
