yesterday
Hi People
I have this task where it needs to be checked if a Cell in excel is colored or not. How can this be solved with Blue Prism? Is the only way to achieve this a self developed code stage or are there other simple work arounds?
Thanks in advance!
yesterday
Hi @NicolasSahli , you can filter the Excel file by color here like the example below:
You can use this action in MS Excel VBO the action called "Apply Filter - ByColor" then pass the color value
To delete if you have a lot of rows you can got to special to select visible only, also in MS Excel VBO, and use other action to delete
If you want I can explain better about this actions
yesterday
Hello @NicolasSahli
Yes you need to create a custom code
We can help you.
Do you mean that you want to find the next collored cell ?
yesterday
yesterday
Thank you for your Help and Ideas. I ended up just creating a custom code stage which extracts the Value of the Color of the Field.
I did it with that simple line:
ColorValue = GetInstance(ExcelHandle).ActiveCell.Interior.Color
