Difference between recognized data and input on field
AndersonCachiol
Hello!
Can anyone please help me with the following issue?
When I hover the mouse over the highlighted area I want to assign to a field it shows me the correct text that is written in there, ex:
But when I click it to assign to the field, it adds a value different than expected:
It adds this "4" before the correct value. I think that it happens because the string ends on "A" and the field is set as money... (but it still does not make too much sense for me)
Am I doing something wrong? How can I make it work as expected?
BenLyons
Hi Anderson,
It will be to do with your field format and sample header data, plus that you've selected the entire line as your region.
I would recommend just selecting the data you want as your region (29.864,89), either by adjusting the existing region to size or creating a new region.
Ben
