Double click Right mouse button
Murali_MohanKon
Hi Team, For windows application, i need to click Double click Right mouse button. i used "RIGHT" twice. its not working. Please share if any one having idea about this.Thanks in advance.   Thanks Murali Mohan
Mustafa_UlasYig
Hi Mkonanki You can possibly make 2 consecutive ""Global Mouse Click Center"" actions in the same navigate stage with 0,01 set in ""Pause After Each Step"". That should give you a double click. Good luck. BR, Mustafa
Murali_MohanKon
Thanks Mustafa, i have done  this,Its not working for me using windows application.
NetraKurbet
Hi Mkonanki, You can try activating the application and then try double click.   Regards, Netra
Mustafa_UlasYig
...What Netra said! BR, Mustafa
