Error : Could not load file or assembly
14-03-18 01:18 PM
I'm trying to use Mapiex utility to send emails however it is throwing below error.
Internal : Could not execute code stage because exception thrown by code stage: Could not load file or assembly 'BluePrismMAPIExAutomation, Version=2.0.6.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
I have installed Mapiex installer and also tried changing external references to point to right path given below:
C:\Program Files\Blue Prism Limited\Blue Prism Automate\BluePrismMAPIExAutomation.dll
C:\Program Files (x86)\Blue Prism Limited\Blue Prism Automate\BluePrismMAPIExAutomation.dll
How to resolve this issue?
14-03-18 04:43 PM
Make sure you're using the right VBO to go with the installer, and also check that Outlook is the 32bit version - 64bit is not supported.
20-03-18 06:58 PM
And you shouldn't have 2 directories. Copy the files to your BluePrism installation directory (probably the 1st mentioned)
