I have two questions
1. How do you perform the equivalent of an excel vlookup in Blueprism and then copy it down over several rows?
2. I entered information to copy and paste the current accounting period into a data item when I run a process. I entered the period "Q1-2019 Summary" in the environment variables. When I try to retrieve the accounting period information from the environment variables, I get an error message that says something like the code stage cannot be found. When I enter the information manually in the data item the process runs fine. Do you know what is causing the error message?
Diana
