Exception during remote setforegroundwindow
zainebdhifli
Hi, I am facing this error when I tried to activate window in win32 mode. Could anyone please help me to handle this error
Exception during remote setforegroundwindow - System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at BluePrism.ApplicationManager.Operations.WindowOperationsProvider.ForceForeground(IntPtr windowHandle)Choice' - Unable to match any windows with the query terms
Thanks!
zaineb dhifli
6 REPLIES 6
PabloSarabia
Level 11
Hi @zainebdhifli1
I assume that you are getting this error when you try to Launch or Attach an application from the Navigation Stage, right?
Or what are you doing to get the error?
See you in the community, bye :)​
Pablo Sarabia
Architect
Altamira Assets Management
Madrid
Hi Pablo,
Thank you for your response, I am getting this error when I am trying to Press button with navigate stage.
Can you help me please to solve this issue?
Thaks§
zaineb dhifli
Do You have the Application atrached before sending the press action?
Bye 🙂
Pablo Sarabia
Architect
Madrid
Yes the application is attached before sending Press button.
zaineb dhifli
NileshJadhavBP
Level 10
Spy the border of application and use that for activate application and use focus before press or click.
Hope it will help you.
Nilesh
Nilesh Jadhav
Senior RPA Specialist
ADP
India
Nilesh Jadhav.
Consultant
ADP,India
ManpreetKaur1
Level 8
Hi @zainebdhifli1,
Activation of any window is always done by spying the outermost part of the window and then using 'Activate application' action using Navigate stage. This is applicable for any kind of application.​
Manpreet Kaur
Manager
Deloitte
