Global send key and ALT (^) key stroke in Notepad
BernardTheroux
Hi
I try to use the ALT key in notepad like {ALT}+f "@f" to open the file menu. It doesnt work it just write @f in Notepad, but if I do {CTRL}+s "^s" to save the file it promt me with the window to save the file.
Can someone help me?
I'm developping with Blue Prism 7.1
Bernard Theroux
Blue Prism Certified Developper
Bell Canada
Montréal, Qc, Canada
Bernard Theroux Blue Prism Certified Developper Bell Canada Montréal, Qc, Canada
MichealCharron
Level 8
@BernardTheroux
I don't use send keys all that much but looking in the .Net Sendkeys documentation, it says that the "%" is used for the ALT key:
Micheal Charron
Senior Manager
RBC
America/Toronto
Micheal Charron
RBC
Toronto, Ontario
Canada
Hi Bernard Theroux,
As mentioned for Shift(+), CTRL(^), Alt(%)
AlT+F - Try using "%{F}" it will open the file menu
Refer this Global send key documents for
https://community.blueprism.com/viewdocument/global-send-keys-a-guide-to-send
Harish M
Lead developer
America/New_York TX
Harish Mogulluri
