31-05-21 03:05 PM
Also, when I checked my event logs I got this,
Application: dotnet.exe
CoreCLR Version: 4.700.20.11803
.NET Core Version: 3.1.3
Description: The process was terminated due to an unhandled exception.
Exception Info: Microsoft.Data.SqlClient.SqlException (0x80131904): CREATE DATABASE permission denied in database 'master'.
Application '/LM/W3SVC/2/ROOT' with physical root 'C:\Program Files (x86)\Blue Prism\Authentication Server\' failed to start process with commandline 'dotnet .\ImsServer.Web.dll' at stage 'PostStartCheck', ErrorCode = '0x8027025b', assigned port 16238, retryCounter '1'.
Please help me solve this issue.
Ansar
25-09-21 08:28 AM
17-03-25 12:10 PM
Hi both, what was the issue with IIS pool and how did you fix it? We are facing the same problem with installing HUB 5.1. Please give us some hint how did you fix it?
