HUB- Something went wrong issue
ChaithanyaKumar
Hi community,
Hope everyone are doing well!
I have successfully installed hub with all the pre requisites in place. I have also configured authentication server and mapped the user properly, blueprism login can be done using authentication server but no data is showing up in hub(control room).
Steps tried :
  • Restarted IIS and ensured proper bindings to all hub websites
  • Certification mapping is done as per pre requisites
  • Database user have appropriate permissions to access databases
Is there anything, I can do to resolve this issue ???
Chaithanya Kumar K L
RPA developer
Bengaluru
7892048438
24 REPLIES 24
Hi Tejaskumar,
There could be a number of things that have happened here so I really think this is one for support@blueprism.com. That way all possible options can be checked and resolved.
Cheers
Joe Farr
Senior Product Specialist
Blue Prism Limited
Hello Chaitanya,
Did you find the root cause and solution for this issue? Even I am facing the same problem.
Pushpa
CHOKKAKULA Pushpa
Hi Chokkakula,
Could you elaborate more what is the issue and with the screenshot?
Abhishek
Abhishek Kumar
Hello Abhishek,
When I log into the authentication server its showing Something went wrong and I am even unable to load the control room data.4288.png
When I load any sites other than hub.local and authentication.local it's showing as below. Could it be the reason?
Pushpa
CHOKKAKULA Pushpa
There can be many reasons, please do below checks.
  1. Check whether in Database app pool identity access has been provided or not.
  2. For SSL certificate you have used for site, make sure the private key access has been given to respected app pool identities.
  3. If you can't see anything in web based control room. Make sure you did above checks and additionally you need to reinstall blueprism API which is required to make it work. One thing to remember, only one database can be configured per blueprism api hence make sure you are using the same database name in blue prism API and in the hub to see the control room details.
  4. Notification , signal etc. you can't reach it because site data is not available but it is required for some other mean (Haven't explored much but for me as well notification site was not reachable so no need to worry.)
  5. Also please check the authentication server error logs and hub logs may be something you can find useful.
Abhishek Kumar
Hello Abhishek,
Can you please tell me how the first two steps can be done.
Thanks in advance.
Pushpa
CHOKKAKULA Pushpa
we were getting this at a client site and the reason was that the certificates were not placed on the user machines. It sounds weird to me but it resolved the issue completely. We copied the certificates from the server to the user machines and the issue was gone.
Best regards
Zdenek
Zdeněk Kabátek
Head of Professional Services
NEOOPS
http://www.neoops.com/
Europe/Prague
We have installed Blue Prism Hub and the required configuration on server . May I know the requirements and steps needed to view the control room in browser in the client systems. In client systems also is the entire hub and authentication server setup needed to open control room in browser?
CHOKKAKULA Pushpa
Hi Chokkakula,
You don't need to configure anything in Client, everything should be done on server where hub and authentication server is configured.
You need to grant required access rights to the hub user in Blue prims application so that it can read the data from control room. Also give the required rights to the IIS APPPOOL\Blue prism API user in database where you have installed the Blue prism API.
The reason of copying the required certificate to the user machine is to access the site from client machine but this is only required when you use url name as something different from server name FQDN. If you follow the blue prism docs or tutorial, it was mentioned to use hub.local and authentication.local but these names are not recognized by the client. Therefore it is better to use server name FQDN instead of above names for configuring hub and authentication server site because in this case if you use certified SSL it will be correctly authenticated by all the machines. However if you configured the hub and authentication server with the names hub.local and authentication.local then you need to copy the certificate into all the required client machines too.
Abhishek Kumar
Hello Abhishek,
Doing this can I open authentication.local in client system in browser? Will it work?
Pushpa
CHOKKAKULA Pushpa
