11-09-21 12:20 AM
I have a SSO environment and I'm attempting to set it up so that my Resource PCs connect to the application server. I have followed the guide and setup the login Agent but my Resource PCs only work if I login manually to them. If I reboot them they aren't connecting to the Application server. I'm fairly certain I've done something wrong but would appreciate pointers to get me headed in the right direction.
I have setup a login script and it successfully works so I'm fairly certain that I'm just missing the part where the resource pc starts.
Manually I can run this as a batch file and it works.
"C:\Program Files\Blue Prism Limited\Blue Prism Automate\Automate.exe" /resourcepc /sso
11-09-21 05:19 AM
Hello Tracy,
Is your Resource PC connected to a resource pool where in the login agent is configured from control room?
Best Regards,
Ved Sengupta
Deloitte India(Offices of the Us)
Bangalore
11-09-21 05:19 AM
Hello Tracy,
Best Regards,
Ved Sengupta
Bangalore
