Help for Window Press Keys Action
Hi, I am running blueprism Version 5.0.30.0 and would like to send keystrokes like CTRL+A and CTRL+C to an edit. I can focus that edit field and can type into it, but I can't figure out how to press the special keys, All help and documentation I can find is for the Global Send Keys and Global Send Key Events actions, which I don't seem to have in my version. The properties of the navigate stage in my version give me "Window Press Keys" and "Window Press Keys with Alt" in the context of my edit element. "Global*" I only have mouse-click-actions. Is this possible at all in v5.0.30.0? And if so can you point me to a place where I can find out how to do it? Thank you for reading this and have a nice day, Marian
JuhoLindblad
Hi Marian, You can use Global Send Key Events with ""{CTRL}"" and ""{CTRL}"". Note that you have to select the top element from the Application Modeller tree to use it. Remember also to activate the correct element before using Global Send Key Events. Hope this helps, Juho
