How Start or Remove a Pending Process using Command Line
10-11-20 06:19 PM
Hello guys!
We are trying to start or remove a process which is already pending in control room without press "delete" mouse button. The initial idea was for find any command line for remove, clear pending itens or any other option.
The currently status is that:
Someone can help?
Very Thanks!
Gustavo Klein
System Analyst
UTC
11-11-20 06:09 AM
to Run pending session get object from Run pending sessions object
Jerin Jose
RPA Product SME
EY
*"If you find this post helpful, please press the "Recommend" Button.*
11-11-20 06:27 AM
11-11-20 08:44 AM
this Object was provided for BP Version 6.3 and was also working in Version 6.4.
But now (e.g. in 6.7.1 we are currently using) this object doesn't work anymore. At first you get a compilation error (see Attachement)
So I tried to fix it, like the User to "New String(){user}, " and clsTalker needs a Timeout Value now.
Then it compiles again, but obviously Talker.say("delete" .." is not working in 6.7.1. It doesn't delete the session. it is still pending
see changes here:
Do you know how Talker is working now? Is there any description?
Thanks and Kind regards
AJ
PS: We'll also Need those "delete pending session" stuff, because we have same problem like here: https://community.blueprism.com/communities/community-home/digestviewer/viewthread?GroupId=145&MID=1519&CommunityKey=3743dbaa-6766-4a4d-b7ed-9a98b6b1dd01&tab=digestviewer
12-11-20 11:24 AM
Gustavo Klein
System Analyst
UTC
18-06-21 04:20 PM
S D
consultant
NoName
02-09-21 10:39 AM
Having same issue with the provided process(SessionClearer-bprelease.zip ).
Is there any chance to fix Talker() functionality to work with BluePrism v6.10.2? Maybe someone can provide correct usage of Talker() in latest product version?
Oleksandr Bezuglyy
Metinvest Digital
