How to add as external reference Microsoft ADO Ext. 2.8 for DDL and Security to business object
Hi! I'm currently working with MS Access databases and I need function to create a new .accdb files, but it seems that the only way to perform this is by using 'Microsoft ADO Ext. 2.8 for DDL and Security'. How can I properly add this library as external reference to my business object?
I don't know if it is what you are after, but how to add dll references to your Blue Prism objects is outlined in the 'Blue Prism Data Sheet - Extending Automations using the .NET Framework' data sheet in the Product Documentation area of the portal.
