How to connect a remote aix or unix server, run some commands and get outputs
JunTan
Is there a VBO to connect the remote server(AIX or Unix) and run commands/get commands output? I tried use putty and use region to do this,it working on my computer but not working on others' computer.
What you need is a terminal emulator.... if you work for a large organisation your company may already have licenses for one.   The think to ensure is that the terminal emulator you select is hllapi compliant (that is the standard API interface that  the Blue Prism mainframe emulator interface uses).  There is lots of help on the portal related to mainframes.
