Not Able to run Active Directory Commands through Blue Prism
14-02-23 11:51 AM
Hi everyone,
In my project we have upgraded the BP version to 6.10 from 6.4. We were able to run powershell commands and connect to active directory to fetch data and make changes to it. However after upgrading to 6.10 BP is not able to fetch data from active roles server.
Result with BPv6.4 on searching a user - user found
Result with BPv6.10 on searching a user - No result upon searching the user with LAN ID
Can someone suggest a solution forthis?
Sudha
EY
14-02-23 12:05 PM
Hi Sudha,
If you debug the process and run into the object:
- what stage is giving an exception?
- what exactly does the exception say?
Happy coding!
Paul
Sweden
Happy coding!
Paul, Sweden
Paul, Sweden
