How to consume Restful webservice?
YogitaKulkarni
Hi, We are querying a database using 4 dynamic variables and then using the data in the process. As of now, we are using a modified version of OLEDB connection object. However, we want to migrate to a webservice which will be taking the 4 parameters as input and a collection will be given as output from the database. The webservice is a RESTful webservice. Can someone help on methods of execution? Do we need to write additional code for this?
AdamSørensen
Im pretty sure BP only directly supports SOAP, so you'll have to Write additional code for this. You can try to use a WebClient or use https requests or something in Your code and see if you can get a Connection to the webservice. Remember to add the credentials to the WebClient if you go that route... Something like wc As New WebClient wc.Credentials = New NetworkCredential(user,pw)
__
Is the default ""Webservices - REST"" object not sufficient? It supports OATH and simple HTTP requests
Level 15
Webservices are great if you are communicating data accross domains or accross the internet. For communication within a domain I actually thing database communication if possible is a simpler and more robust method of providing source data to a Blue Prism solution than using web services. As mentioned, Blue Prism does not provide native support for RESTful web services - only SOAP is built into the product. However, they do provide HTTP and JSON objects with the product (in the VBO folder) but you will need to have the developer/programmer knowledge to use these to create the interface to your bespoke web service. Maybe contact your Blue Prism DEM if you require more help with this.
YogitaKulkarni
Thanks. As of now, I have written a code which tries to call the webservice, but there are some problems in that. It is saying that for calling, the webservice needs to be HTTP and not a HTTPS webservice. It is known that this is a HTTPS webservice with SSL security. Does anybody has a clue on how this can be worked around?
