How to extract particular value from response content json using json path dynamically with input parameter
AZ
Hello All,
How to get perticular value from response content using json path method and pass input parameter as dynamic value in the below expression.
$.employees[?(@.lastName == 'Smith')].firstName
Here Smith need to be replace with input parameter and not a fixed string.
How can we get this dynamic approach in web api request
K
A Z
This might not be what you want but take a look at the ExpandoObject, seems to be a convenient way to get an object representation of the JSON that you can then traverse.
Dim objJSON As Object = JsonConvert.DeserializeObject(Of ExpandoObject)(strJSON)
John Carter
Professional Services
Thanks John
K
A Z
