How to get a specific document from Decipher?
Let's say I have 3 users working on different projects in Decipher and when anyone runs get verified process it basically grabs everything from Decipher into a queue.
Is there a way I can divide the chunk according to batch-type/DFD/doc-type or any level?
Or anything else that can basically break this workflow as per some rule.
Thanks & Regards,
Tejaskumar Darji
