12-09-23 07:08 AM
Hi everyone! Could you help me to find a solution? I don't understand, how can I get the values from XML. I have the XML as below. My goal is to get the values of " Row_3" and " Row_4" inputs. So, I need to find in the output the values 3333 and 4444.
<parameters>
<inputs>
<input name=" Result" type=" text" value=" List"/>
<input name=" Data" type=" collection">
<row>
<field name=" Row_1" type=" text" value=" 1111"/>
<field name=" Row_2" type=" text" value=" 2222"/>
</row>
</input>
<input name=" Row_3" type=" number" value=" 3333"/>
<input name=" Row_4" type=" number" value=" 4444"/>
</inputs>
<outputs/>
</parameters>
Thanks!
12-09-23 10:08 AM
Hi Demyan,
You can use the Utility XML VBO for this and using get element by path you can get the values respectively
12-09-23 01:41 PM
Hi Demyan,
I'm assuming that there is an <output> tag after the <parameters> but before the <inputs> tag? I believe your missing that one in your example. Does the name=" Row_3" change or does it remain the same with every XML?
Thanks!
