How to pass ( ) into Send keys
sapna_soni0290
I want to pass my shared drive path into send keys
C:/ABC/XYZ (R drive)/Randon values/Random Values.xlsx but because of ( ) its not able to write values & throw exception as group delimeters are not balanced.
Please suggest how can i pass my values . I am using Env variable data type to pass this.
5 REPLIES 5
Hi  sapna soni,
Try to use copy and paste clipboard instead of using global send keys
Harish Mogulluri
sapna_soni0290
Hi Harish ,
How can i use Copy clipboard action . Please elaborate steps & syntax.
Hi Sapna Soni,
You can pass the text from the input parameter by using below VBO
VBO: Utility - envioronment
Action:
1) Clear Clipboard
2) Set Clipboard(set the data item that you want in the Clipboard)
3) you can use Global Send Keys: ^v to paste the data in the desired place.
For the step 3 you can try Global send keys if it is not working then you might need to create C# or vb.net code to escape special characters
Harish Mogulluri
sapna_soni0290
HI,
Has someone passed ( ) into send keys in navigate stage. If yes, plz let me know how to bypass this delimiter?
plnarayana777
Level 7
Hi
I hope you have already solved your issue
Still you can check this by enclosing in this way {(} , {)}
so if you are long text then you can use replace function to replace ( with {(} and ) with {)} in calculation stage
Lakshmi Narayana
