How to use Mouse right click Using global send key
avinash.k
I want to do a mouse right-click on the check box using the global send key.
Avinash Kumar
7 REPLIES 7
Deep.Shah
Try Shift + F10
Deep Shah Senior Developer/Mentor
Smart Automation Services
Hi Avinash
To do a right click you only need to spy the element you need to press then using a navigate stage set the element to focus. Add a second step in the navigate under  the focus and add the root application element to this then select Global mouse click or Global mouse click center, in the mouse button options enter "RIGHT". This should work to right click the button for you.
Out of curiosity can I ask why you need to do a right click on a checkbox item?
Hope this helps
Michael ONeil
Technical Lead developer
Everis Consultancy
SomashekharD
Avinash, hope this will help you
Mouse right-click Global Send Key expression "+{F10}"
Mouse right-click Global Send Key events expression "<{SHIFT}{F7}>{SHIFT}"
FYI, good reference on key codes for Send Keys here: http://www.nncron.ru/help/EN/add_info/keys_mnemonics.htm
Somashekhar
America/Chicago
Hi @Somashekhar D
Is it possible to use global send key for Mouse left click?
A A
Europe
Hi A A
There are 2 ways you can do a left click you can either select Global Mouse Click or Global Mouse Click center from the navigation actions for you element and in the mouse click parameter simply enter "LEFT" or if you prefer to use send Keys you can select Global Send Keys and enter the value "+{F9}"
Hope this helps
Michael ONeil
NTTData
Hello Michael,
Is there a way to press and hold left mouse button with send Keys?
Some extension to the "+{F9}" ?
Thanks in advance
Cristian Tig
Hi @Cristian Tig
I've never tried to do that before but I guess if you add in "{SHIFT}" either as ​an additional step in the navigation action or with the "+{F9}" step.
Hope this helps​
Michael ONeil
NTTData
