IE Read Write query using collection
AodhanCarberry
Hi All, I'm trying to use a loop to write a collection to a web query. We need to use a choice stage to determine what spied element it should be using before writing the collection to the query fields. It writes to the site fine but I encounter issues when a blank value is pulled from the collection and written to the site. Is there a way to only write data if that particular collection field contains data or do I need to hard set each of the data items instead of using a collection? Thanks.
Ravindersaini
Level 7
Hi, You can use the utility-Collection manipulation to remove empty/Null rows from your collection. Regards, Ravinder
