I suggest checking your data type.
15-12-20 08:11 PM
16-12-20 11:37 AM
13-10-22 10:18 AM
16-10-22 08:20 AM
15-11-24 03:05 PM
hi, with this answer, I need a timespan to be in my data as Excel can't give me the correct answer when looking for the time difference between two times (across 2 dates).
If I simply change the TimeSpan to Text, then all my previous work wouldn't work as I need the timespan. How do I get the timespan to a text without just changing the drop down please so it can write to excel?
15-11-24 03:38 PM - edited 15-11-24 03:39 PM
If are just looking to use the Set Cell Value in Blue Prism's MS Excel VBO, you can simply put the TimeSpan data item into the Value parameter. When you drag the data item into the parameter Blue Prism will complain that that is not the correct data type but at run-time it will automatically cast the TimeSpan as text.
