29-01-26 09:37 AM
Today - When i tried to install the BPE installer for v 7.5- i met with following error.
but Yesterday i did not get such error and i am able to installer from yesterday's msi File [As visible in background ]
Is there any issue with installer.
#bpe #7.5
29-01-26 09:44 AM
Hi @Neel1 - can you try redownloading? The file size for the second installer in your screenshot seems to be smaller than it should be, I suspect the download may have been cut short.
29-01-26 09:44 AM
29-01-26 10:05 AM
Thanks @Michael_S I tried downloading it twice but got the same error but now it is working. File size is showing fine as well.
May be it is issue at the time frame only for me . A Glitch in matrix 🙂
