Hey Josefine,
I am not aware of just sending out the alt key though but if I remember in mainframes usually we send a combination of some other key with a Alt key for various functionality. Can you tell me do just want to send the alt key or any combination of some key along with it. I will be looking for the solution till then for this though.
Also, while trying % key did you first activated the window, focused the element and then used the send global keys action with the root node of your application tree?
Intelligent Process Automation Consultant
Blue Prism 7x Certified Professional
Website:
Hope it helps you out and if my solution resolves your query, then please mark it as the best answer
WonderBotz India Pvt. Ltd.
