Largest Decipher Installation
terry.woods_957
What examples are there of large document volume implementations of Decipher? We find it can take 1 minute per document to extract data. Is this a typical value? What volumes are typically used for determining the capacity of a Decipher instance and when to scale?
Thank you.
Cheers!
Terry
Ben.Lyons1
Hi Terry,
The time taken by Decipher to process documents depends on a number of factors including document length, language, complexity of data to be validated/extracted as well as the available resources for Decipher. Guidance on scaling and performance can be found at: https://bpdocs.blueprism.com/decipher/Guides/Architecture/sizing.htm
Ben
Ben Lyons
SS&C Blue Prism
UK based
