Lost connection - Runtime resource
KevinJørgensen
I have run into a problem with our BluePrism setup. We have 15 Virtual Machines running in parallell and at random time all of them lose connection (at the same time) to the App server and the Runtime Resource stops working. This lead to all VMs being noted as "Missing connection" in Control Room and we have to log in and log out of each of them separately to reactivate them.
When this occurs the process currently running a specific VM stops in place and has then to be restarted when we get the connection back up again.
Our BP version is 6.7.1 if that is of interest and the first error message that shows up from Event Viewer (when the connection is lost) is as follows:
Description:
BluePrism.AutomateAppCore.Resources.ResourceRunnerBase
[2022-10-14 13:10:25Z] Listener failed : failed to update resourcepc details on the database - System.Data.SqlClient.SqlException (0x80131904): A connection was successfully established with the server, but then an error occurred during the login process. (provider: SSL Provider, error: 0 - An existing connection was forcibly closed by the remote host.) ---> System.ComponentModel.Win32Exception (0x80004005): An existing connection was forcibly closed by the remote host
Server stack trace:
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, UInt32 waitForMultipleObjectsTimeout, Boolean allowCreate, Boolean onlyOneCheckConnection, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal oldConnection, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionInternal.TryOpenConnectionInternal(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
at System.Data.SqlClient.SqlConnection.TryOpenInner(TaskCompletionSource`1 retry)
at System.Data.SqlClient.SqlConnection.TryOpen(TaskCompletionSource`1 retry)
at System.Data.SqlClient.SqlConnection.Open()
at BluePrism.AutomateAppCore.clsDBConnection.SetupCommand(IDbCommand cmd)
at BluePrism.AutomateAppCore.clsDBConnection.ExecuteReturnDataReader(IDbCommand cmd, CommandBehavior behave)
at BluePrism.AutomateAppCore.clsServer.GetResourceIdAndFQDN(IDatabaseConnection con, String resourceName, String& fqdn)
at BluePrism.AutomateAppCore.clsServer.RefreshResourcePC(String resourceName, ResourceDBStatus status, Int32 runningSessions, Int32 activeSessions)
at SyncInvokeRefreshResourcePC(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at BluePrism.BPCoreLib.Extensions.RethrowWithStackTrace(Exception this)
at BluePrism.AutomateAppCore.MyExceptionHandlingMessageInspector.AfterReceiveReply(Message& reply, Object correlationState)
at System.ServiceModel.Dispatcher.ImmutableClientRuntime.AfterReceiveReply(ProxyRpc& rpc)
at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at BluePrism.AutomateAppCore.IServer.RefreshResourcePC(String name, ResourceDBStatus status, Int32 runningSessions, Int32 activeSessions)
at BluePrism.AutomateAppCore.clsListener.RefreshDBWithCurrentState()
ClientConnectionId:77c684f7-5016-48de-a872-160e44df153e
Error Number:10054,State:0,Class:20
Any advice would be greatly appreciated!
henrynli
Hi Kevin,
The problem seemed to relate to SQL server access.
Did you check with related teams to find out what recent changes were made ? This might be important as likely the changes triggered the problem.
There is a KB Article : https://portal.blueprism.com/customer-support/support-center#/path/Automation-Design/Studio/Code-Stages/1349460292/How-do-I-fix-error-SSL-Provider-error-0-The-client-and-server-cannot-communicate-beca... but not sure if this one would help.... the Direction is to find out the recent changes, likely relating to SQL server or if the SQL server has been stopped while BP system was running..... You can isolate issue by restarting the BP server .
If problem persisted and you confirmed nothing changed with policy/environment, log a ticket with support.
Henry
