Merge Collections based on Key Field
ChrisHodgson1
Hi, I'm looking to merge two collections with different columns that have one column with data that will match between them. Looping through both into a new collection does work, but takes far too long with collections that have 1000+ lines. Is there a way of merging them in a way similar to a SQL "Join" query? If so, does anybody have any example code? Thanks in advance, Chris
12 REPLIES 12
StuartRedmore
Hi Chris, I have attached it. The parameters are: In : Collection_One - Datatable In : Field_One_Name - String In : Collection_two - Datatable In : Field_Two_Name - String Out : Collection_Out - Datatable Out : DataTableLen - Decimal Naturally Datatables are the collections. The code I've written is basically the form of ""Left join"" , but it wouldn't be difficult to change to an inner join if that's what you needed. It only works on a single column to column relationship, these being Field_One_Name ( this must exist in Collection_One ), and Field_Two_Name ( this must exist in Collection_Two ).  but again it wouldn't take much work to expand this. You can ignore / remove the DataTableLen item from the code and output, I added it whilst debugging and simply forgot to remove it. Please let me know if i can help further.
ChrisHodgson1
Hi Stuart, That object worked perfectly! Thank you very much for your help I really appreciate it. Chris
Can you pls help me with the same code as well
Saumya Sinha
