Need to chaneg Active directory group
PankajWalia1
We need to configure BP role to a different AD group but not able to do it as the AD group field is not editable.. please advise.
If you are not able to edit a group then it could be because: a) The user you are logging in with does not have sufficient permissions in Blue Prism (i.e. is not a member of the defined Blue Prism Administrators Active Directory group) b) You are trying to change the AD Group of the Blue Prism Administrators, and this needs to be done in the System -> Single Sign On screen. Hope that helps. Chris (BP Support)
