03-07-23 04:47 PM
Hi All,
I am facing issue while untagging Queue item " Internal : Tags cannot contain ';' (semi-colon) characters". I got the solution - tag should not have ';' (semi-colon) character. I want to know the list of characters which are not supported in untagging. Also link for the document for the same so I can read more on it. Thanks for the support.
Priya
03-07-23 06:23 PM
Hi priya Sangle,
Open action stage and Select as mentioned in teh screenshot. select "i" icon which was highlighed it will open BP Documentation for the work queue action
As mentioned in the documen(Below screenshot)t untag item action > Parameter Tag should not start with "+" or "-" and also it should not contain Semicolon";"
03-07-23 06:23 PM
Hi priya Sangle,
03-07-23 10:02 PM
Got it.
Thanks for quick reply.
