Not able to identify any element on Chrome
NirajKumar1
I am not able to identify any element on the chrome with any mode(Browser mode, UI automation mode, Region mode, AA mode).
Could anyone please tell me how to deal with it.
Thanks in advance.
Niraj Kumar
Application Service Engineer
Siemens
11 REPLIES 11
GopalBhaire
Level 10
What version are you using?
Pretty sure that BP hasn't attached to chrome properly. Close all instances of Chrome and launch again using BP.
Gopal Bhaire
Analyst
Accenture
Walter.Koller
Level 11
Is this problem solved?
I am facing a similar issue where I can spy Chrome application (Window, address bar, ...) but I cannot spy any element within the page. I have tried suggestions here: Chrome Automation but without success. We are still using BP 6.4.0 ​and Chrome 75.0.3770
Walter Koller
Solution Manager
Europe/Vienna
Yes, it is working for me now. I have just closed all the instance of Google Chrome and then tried, then I was able to spy every element within the page.
------Original Message------
Walter Koller
Solution Manager
Europe/Vienna
Niraj Kumar
Siemens
​Thanks for the reply.
Unfortunately this was not the issue for me.
Walter Koller
Solution Manager
Europe/Vienna
Have you double checked that the Chrome extension you are using is the one specific to version 6.4?
If so, we found that a Chrome update seemed to break our spying. The suggested workaround was to:
  1. In the Chrome URL, enter: chrome://flags
  2. In the search field, look for the setting: "Enable network service"
  3. Disable that setting
If that is unsuccessful, could you verify if other websites have the same issue?
Matthew Young
Analyst- Robotic Process Automation
CarMax
America/New_York
Thanks for your reply.
Unfortunately it is not possible to stick to one version of Chrome extension since it is downloaded directly from Chrome store during installation.
Therefore we have now
Chrome Extension 1.0.6.3
Blue Prism 6.4.0
Chrome 75.0.3770.90
I have tried now to increase BrowserAutomation.DefaultCommunicationTimeout to 10000.
Added parameter --force-renderer-accessibility to the URL for enabling UIA.
Disabled "Enable network service" in Chrome.
I have tried to spy https://www.google.com but with the same results.
Strangely I cannot spy any elements with any mode on my laptop but I am able to spy elements in UIA (but not browser mode) on one of our virtual machines. However, spying works there but Blue Prism cannot find them afterwards (highlighting fails).
Walter Koller
Solution Manager
Europe/Vienna
Hi Walter,
I Was facing same issue with chrome, I can spy but its not highlighting afterwards.
Did you found any solution.
Goutham Ch
Unfortunately we didn't find a solution since our Chrome version was frequently upgraded, out-versioning the compatible extension that can be used with Blue Prism 6.4. Chrome upgrade frequency is a real issue in our environment. Hopefully the situation became better.
We partially upgraded to 6.9 with the respective Chrome extension and it works now to create processes but it is somehow unreliable when executing.
Other processes are still using IE, which is more stable.
We still have to evaluate Edge, though.
Walter Koller
Solution Manager
Europe/Vienna
