OLEDB Excel - Invalid Sql Statement
JonathanHolstin
I'm trying to pull a simple ---
Select * From [Excel Sheet]
Could not execute code stage because exception thrown by code stage: Invalid SQL statement; expected 'DELETE', 'INSERT', 'PROCEDURE', 'SELECT', or 'UPDATE'.
I'm trying to use various versions of the following statement. With [Excel Sheet] data item being the excel sheet MCDR with a $ after. So [MCDR$]
"select"&NewLine()&
"*"&NewLine()&
"from"&NewLine()&
"&"'"&[Excel Sheet]&"'"&"""
Jonathan Holstine
Systems Accountant
Interior Business Center
America/Denver
RajathGopal
Hi Jonathan,
Good Day!!
The syntax would be "Select * from [Excel Sheet$]".
The sheet names would be suffixed with a $ symbol.
Rajath G
Sr. Blueprism Developer
ITC Infotech
Rajath Gopal
Associate IT Consultant
ITC Infotech
8904867411
sutirtha.gupta
Hi Jonathan,
Can you please do the get worksheet names first and check is there any difference in worksheet names?
Sutirtha Gupta
TCS,Kolkata
------Original Message------
"select"&NewLine()&
"*"&NewLine()&
"from"&NewLine()&
Jonathan Holstine
Systems Accountant
America/Denver
RajathGopal
Hi Jonathan,
Good Day!!
Rajath G
ITC Infotech
Rajath Gopal
ITC Infotech
8904867411
Thanks Rajath. Looks like it was that simple.
When I ran it using Microsoft.Jet.OLEDB.4.0 I got it to go through but it could not find the file. I was wondering if that is because I'm on a new version and the Jet appears to be for older excel. In trying to change to the ACE connection I am running into problems of not conforming. Details below. Any ideas?
Could not execute code stage because exception thrown by code stage: Format of the initialization string does not conform to specification starting at index 130.
"Provider=Microsoft.ACE.OLEDB.12.0;Data Source='P:\Libraries\FSB\AOBRobotics\MCC\Invoices - MCDR\NPL CIF MCDR - November 2019.xls';
Extended Properties='Excel 12.0 Xml;"
Any ideas on this....?
Jonathan Holstine
Systems Accountant
America/Denver
Hi Jonathan,
Looks like a few parameters are missing in your connection string. Try using the below connection string :
"Provider=Microsoft.ACE.OLEDB.12.0;Data Source="FilePath";
Extended Properties=""Excel12.0;HDR=Yes;IMEX=1;"""
Rajath Gopal
ITC Infotech
8904867411
