Overlapping processes using schedule
ValerioValrosso
Hi, i need to periodically check if a work queue is not empty in order to make a process start. I can do this using schedule. The problem is: if a process is running, and the scheduler founds that the queue is not empty, it will start a new process, so there will be two of the same type. How can i make the schedule/process check that there is no active process before starting? Best regards
0 REPLIES 0
