29-10-20 02:11 PM
29-10-20 02:47 PM
How to resolve this issue
Search "PCSHLL32.DLL" file on the client machine and then:
The %windir%\system variable retrieves this directory's path for 64-bit files on a 64-bit OS, and 32-bit files on a 32-bit OS. For 32-bit files hosted on a 64-bit OS the directory is %windir%\SysWOW64
However, if the file "PCSHLL32.DLL" does not exist in the client machine, or if the first solution does not resolve the issue, then please do the following:
14-03-24 12:09 PM
I already performed above but still getting same error while trying to attch "Internal : Failed to perform step 1 in Navigate Stage 'Attach' on page 'Attach' - Terminal Emulation - Could not load the dll - PCSHLL32.DLL"
can someone help on this?
15-03-24 01:41 AM
Hi Preeti,
Check knowledge base solution 2. https://support.blueprism.com/en/support/solutions/articles/7000078188-bpe-error-failed-to-launch-application-launch-failed-terminal-emulation-could-not-load-the-dll-
