PDF Management Error
17-03-20 12:45 PM
Hi
I have installed Object "PDF Management".
It works on my local computer, but my collegues are unable to use it.
Error message is in attachement.
Please tell me if you faced such issue and found solution.
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
Mateusz Wojcik
RPA Programist
Rockwell Automation
Europe/Warsaw
12 REPLIES 12
11-04-22 02:58 PM
My best guess is that it does not work with latest PDF formats from Adobe. That is where it fails. All the old PDF format it works fine.
Hence I was also suggested to use official PDF toolkit from DX that uses Adobe licensed services and DLL to perform such pdf actions.
Thanks & Regards,
Tejaskumar Darji
Thanks & Regards,
Tejaskumar Darji
11-04-22 03:51 PM
Dropping the link to PDF toolkit from DX here
Thanks & Regards,
Tejaskumar Darji
Thanks & Regards,
Tejaskumar Darji
07-06-22 04:54 PM
Thanks & Regards,
Tejaskumar Darji
Thanks & Regards,
Tejaskumar Darji
- « Previous
- 1
- 2
- Next »
