Performance issues after Blueprism 6.6 upgrade
03-02-20 04:16 PM
After the upgrade, during the initial validation, we have noticed that the processes take an unusually long time to load inside the process studio.
A single process takes around 4.5 minutes to load, which will definitely have an impact on our developer productivity.
The same process when opened in another digital worker, on BP v 6.5 takes around 90 seconds, which is still too long, but something that was known.
Further investigation shows the processor utilization peaking into 90% and the service becoming unresponsive for a period of time before coming back to normal.
I wanted to check-in and see if any of the teams here has upgraded their environments to Blueprism v6.6 and faced any issues. Any pointers to the possible root cause for this performance degradation will also be very helpful.
Thank you!
Uday B
Solution Designer
04-02-20 04:34 PM
That does not seem to resolve the issue. We suspect that the root cause is related to some issue in the way, processes are loaded into the process studio when its started. But the drastic degradation of performance after the upgrade looks like a bug that has been introduced in this version which manifests only in scenarios where there are a large number of processes/objects.
Uday B Solution Designer
05-02-20 12:28 PM
Have you been able to test this in more than one BP environment? We've encountered issues (not loading times though) that only affect a single environment because the database schema itself was broken by a silently-erroneous BP upgrade/installation. Unfortunately the answer we were given at that point was to reinstall the database.
What connection mode are you on? WCF, .NET remoting, ...?
Dave Morris
3Ci @ Southern Company
Atlanta, GA
05-02-20 02:06 PM
The issue exists in databases that have been upgrades, a new database with just a few processes, however does not have this issue of long process load times.
We are currently using .NET remoting. We have tried WCF connection mode in BP v 6.5 but observed very slow response time for the application itself, and a decision was made to stick with .NET remoting until more testing is done.
05-02-20 03:37 PM
Ami Barrett
Sr Product Consultant
Plano, TX
05-02-20 03:40 PM
Junior Nyanga
Software Support Engineer
Blueprism
06-02-20 11:52 AM
Do you utilize TEAMS functionality to logically separate your processes and objects?
Some activites done in the UI seem to be very affected by the number of in the user context. The same activty take 5sek for a developer with a limited number of proc/object count, for me (admin) the exact same activity take 35-40 seconds. If I perform this activity on a server( A lot of power) or a VDI ( limited resources ) ; it doesn't reflect on the time. Utilisation is down as expected though.
What about your Design Control, to what extent do you check? (Open,Resetting,Close)
Hakan Engman
Automation engineer
Teliacompany.com
Europe/Stockholm
06-02-20 02:13 PM
Nicholas Zejdlik
06-02-20 02:33 PM
Design control validations have been disabled, but that did not improve performance.
We are currently working with the Blueprism support team to investigate further.
06-02-20 02:36 PM
We are also looking at infrastructure requirements, space issues and complexity of the processes themselves.
So far the issue seems to be with BP v6.6 and the mechanism for loading processes into the process studio. The high volume of processes/objects(close to 3200) in our case is also amplifying the problems.
12-02-20 09:34 AM
I may be going a bit off topic, But this thread does bring forward the need for BP to come up with database maintenance related documents.
I understand that normally, each org's IT department does the database maintenance, but when it comes to small scale organizations with limited IT resources, the IT team sometimes is reluctant to touch the BP provided tables. They do the generic maintenance and backup though.
A document from BP about the tables/procedures for maintenance/re-indexing etc would be of great help to everyone.
Vivek Goel
