Possible to create collections dynamically?
Hi, Is there any way collections could be created dynamically? For example, I have a Name collection of N names and i wish to loop through the Name Collection to create N collections dynamically without me manually creating in BP. Thanks!
Hi All, Like the TS, I had encountered this similar issue as well, where you do need to make the whole automation more dynamic to respond to changing requirements. I think this should be a major issue faced by many when interacting with things like Excel? Would very much appreciate inputs on this. Thanks! Jay
Hi U59006, ""Is there any way collections could be created dynamically?"" - No it's not possible
FrankBaumann
You could create the collections dynamically in a code stage. Granted that solution will put multiple nested collections in one main collection and the collections will only be populated at run time.
