28-09-20 12:50 PM
28-09-20 01:26 PM
28-09-20 01:26 PM
28-09-20 02:40 PM
28-09-20 02:56 PM
28-09-20 03:00 PM
28-09-20 03:15 PM
28-09-20 03:33 PM
- In case the robot handles a huge amount of emails (shared mailboxes) the .ost grows in size rapidly, causing crashes on the VMs, therefor of the bots.
- the .ost file sometimes becomes corrupted and cannot be opened, only recreation of the .ost file helps.
- the .ost file gives an error, when opening Outlook. Clicking on OK and reopening Outlook again usually helps.
- when .ost file has to be recreated it may take up to hour(s).
Any suggestion on how to adress this issue
28-09-20 05:05 PM
---------------------------------------FROM MICROSOFT---------------------------------------
The OST file format has a maximum file size that depends on the version of Outlook you’re running:
20-02-24 01:40 PM
If any manual process is not working for you, you can go for any professional third party tool like MailsDaddy OST to PST Converter
