Hi Gareth,
First rule of RPA - don't automate a bad business process
🙂 so you were correct to challenge your team!
If only minor rework of the business process is required then capture the existing process (and input from the SME on any improvements), but consider the strengths of RPA in the solution design. Many customers successfully work this way.
- Ensure those responsible for Solution Design (Design Authority?) are familiar with Solution Designer training on the BP University, this includes some considerations for optimising business process to make optimal usage of a Digital Workforce.
- Ensure that the business are aware of any impacts and consulted where necessary.
If the business process requires significant rework, typically the recommendation would be along the lines of Doug/Pritam, "fix" the business process with an eye to automation. If you understand what the final post automation process will look like then consider this in your reworked business process, it'll save you time in future. Let the new business process stabilise before automating. Only mature, highly experienced teams should consider the challenges associated with significantly reworking a business process and automating in parallel.
Hope this helps.
Kind Regards
Andrew
Andrew Beard
Senior Consultant
Australia/Melbourne
